Configure an ACE Source Port
Configure ACE source port entries to have the filter look for packets with a specific source port.
  • The ACL exists.
  • The ACE exists.
  1. In the navigation pane, expand Configuration > Security > Data Path.
  2. Select Advanced Filters (ACE/ACLs).
  3. Select the ACL tab.
  4. Select the appropriate ACL.
  5. Select ACE.
  6. Select the appropriate ACE.
  7. Select Proto.
  8. Select the Source Port tab.
  9. Select Insert.
  10. Specify the operator for the source port.
  11. Specify the port number or port list to match.
  12. Select Insert.
Source Port Field Descriptions
Use the data in the following table to use the Source Port tab.
Name
Description
AclId
Specifies the ACL ID.
AceId
Specifies the ACE ID.
Port
Specifies the source port (1–65535).
Oper
The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.
OperMask
Specifies the mask parameter, {0-0xFFFF}.
